Charges using a power adapter but will not charge from a PC
Hello. I have a iPad mini 5 Wi-Fi version which had damage to the charge port. I replaced the charge port and it charges fine using a 30w Apple power supply. When I tried to connect it to my computer, it does not charge and the computer does not show its connected at all. I tried multiple computers and cables and its all the same. Even when putting the iPad in recovery mode, it does not connect to my computer. I was checking some voltages on the board while it was charging and noticed that PPOUT_E75_ACC_ID1_CONN is always about 2.8v and PPOUT_E75_ACC_ID2_CONN is always 0v. Is this normal? Both measure about .398 in diode mode, so not short. I replaced the Hydra IC just in case, but I still have the same symptoms. Could it somehow be a bad charger flex cable?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
