Zum Hauptinhalt wechseln
The Samsung Chromebook XE303C12-A01US laptop features an 11.6" screen and a 16 GB SSD hard drive. This small notebook computer allows for easy access to the Internet and can run various web apps.
How can I do a hard reset that will put it back to like new
How do I do a hard reset to make it like new
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
If you have access to the pc to login. Then just factory reset in settings, otherwise use a clean drive with a compatible OS of your liking downloaded to it and hook it up. Search the internet for ways to reset without login info if thats a problem, I dont use ChromeOS, but thats the standard for most PCs.
War diese Antwort hilfreich?
Bewertung 0
Hey Shannon! To perform a hard reset on your Chromebook and restore it to factory settings, Try this!
  1. Back Up Your Data: This process will erase all your personal files, settings, and apps, so ensure anything important is backed up (like files in the Downloads folder, as items stored in Google Drive are automatically saved online).
  2. Sign Out of Your Chromebook:
    • Press Shift + Ctrl + Q twice to sign out.
  3. Enter Recovery Mode:
    • Turn off your Chromebook.
    • Press and hold the Esc + Refresh keys, then press the Power button. Release the buttons when you see the recovery screen.
  4. Perform the Factory Reset (Powerwash):
    • When in recovery mode, you’ll see a message saying “Chrome OS is missing or damaged.” Press Ctrl + D to begin the process.
    • Press Enter to enable Developer Mode. (This will erase everything on your device.)
    • Your Chromebook will restart and go through a setup screen. Follow the prompts to re-enable the OS.
  5. Finalize Reset:
    • Once it restarts, you’ll go through the initial setup as if it’s brand new!
After completing these steps, your Chromebook will be reset to its original factory state.
Happy iFixing!
(Formatted by ChatGPT 4o-. Never written)
Bewertung 0
Antwort hinzufügen
Shannon Mitchell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 88
Insgesamt: 890
