I have a Samsung Refrigerator not sure what its called but it between
I have a Samsung Refrigerator not sure what its called but it between the french doors a plastic stripe that is on the left side of door
Ist dies eine gute Frage?
It's your it's door seal. It has a coil inside that stays warm so it doesn't freeze to the frame of the fridge. Also if your having trouble keeping the same temp inside check your fan in the back and make sure it's turning and not turn at a slow speed of it is them it needs replaced. It keeps those hot coils cooled down while the compressor is creating a freezing reaction the the copper coil on inside of freezer and the fridge part. If the coil on the back are dusty and dirty take it and clean them with a vacuum and a paint brush or a broom then suck up the dirt off them. I hope this will help you guys understand...Take care/:) Godbless you!
War diese Antwort hilfreich?
No never suck any parts of fridge blow out😁
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 99
Hi @donna59937
Please confirm the full model number of your refrigerator (in case parts are needed)?
Is it a rubber (or plastic) strip?
If so it sounds like a door seal.
What is the problem with it?
von jayeff
