Zum Hauptinhalt wechseln
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
Can I glue down a connector to the motherboard?
I've accidentally snapped one of the connectors on my new 3ds one of the the ones you don't have a latch on and the whole thing snapped in two and basically no longer exists. I have 4 pads on the motherboard and I've tried taping down the cable. But it won't stay down and will turn off unless I physically push down and hold. Can I glue a flex cable to the pads or solder each individual pad to the flex. I'm useless at soldering so unsure I could solder a new connector plus wouldn't know where to start. Seen the connectors for a couple quid but assume I'd just melt them and this console has already cost me an arm and a leg. Any help would be much appreciated. Thank you in advance
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Any chance you could add a picture of the connector in question? Bilder zu einer vorhandenen Frage hinzufügen
von
Einen Kommentar hinzufügen
1 Antwort
No, you should not glue down a connector to a Nintendo 3DS motherboard
do the following instead
https://en-americas-support.nintendo.com....
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Karl Stirland wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 39
