Zum Hauptinhalt wechseln
My Sony CFS 715s cassette corder volume switch is broken
I am not getting parts of my boombox where can I get it online and geniune parts online with guarantee
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @vaibhavlimaye
Here's the service manual that may help.
According to the parts list on p.24 the Volume control (RV301) is a 20K/20K dual gang potentiometer. The part number is 1-241-106-11
Unfortunately when searching online for the part number there are no results.
You may have to search various electronics parts suppliers for a compatible replacement potentiometer (example only showing various types).
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Can you pls tell me function switch part number?
von
@vaibhavlimaye
Which "function" switch? I've already listed the part number for the Volume control switch above, but as I said there's none available online or none that I found anyway.
Open up the boombox and check what the Volume Control switch looks like and then use the supplier link that I posted to find one that looks the same but more importantly has the same specifications. Usually the supplier I linked has the datasheet listed with each component so you can check if it is compatible i.e. same electrical specifications, same dimensions etc.
von
Antwort hinzufügen
Vaibhav Limaye wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 104
