Zum Hauptinhalt wechseln
The 1998 version is based on the original Beetle but, in comparison with the old model of the vehicle, it is way more spacious and equipped with more advanced features.
2002 Volkswagen Beetle Cabriolet. The steering wheel is very heavy
hi
I have a 2002 Volkswagen Beetle Cabriolet. The steering wheel is very heavy and the hydraulics are leaking from under the car. How can this be fixed please?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I can't say i have pulled that model of Volkswaggen apart. I have worked on earlier Volksy's. I reckon your power-steering rack is leaking and you have lost most of your hydraulic fluid. That is why the wheel is heavy.
You need car mechanic to locate and repair the leak. In order to drive the car fill the power-steering resivour with appropriate fluid. It won't hurt to overfill it as that will buy you more Km's to get it to the mechanics before it all leaks out again. Fill it up just before you drive it. Don't fill it then leave it sitting just to have it leak out.
Witrhout inspecting the car myself it's hard to say but usually it's eaier and more cost effective to replace the steering rack or pump with new and rebuilt components. I know I have had to use the fill and drive technique to get a vehicle to where the tools are. I hope this message has helped, best of luck. Pok Muggins
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Atle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 38
Insgesamt: 143
