My Yocan UNI Pro 510 vape battery blinks 5 times no matter what I do
How to fix it?
Ist dies eine gute Frage?
How to fix it?
Hi @vape64454
You don't say what you've tried so here's a link that may help, in case you missed doing something
Also try tightening the 510 thread adapter as directed then back it off 1/4th a turn and try the cart again
War diese Antwort hilfreich?
Thank you for your help. Have a nice day.
I have a lookah bear 510 thread battery that buy from 420buy.com online headshop, although not a yocan battery, but the problem and solution is similar.
Your yocan battery blinks 5 times is a poor connection problem that can be caused by dirty connection, misalignment, or faulty components.
Carefully clean the connector with a Q-Tip and Isopropyl alcohol (99%). Unscrew the cart a little at a time, but not too tight.
Adjust the connection plate using a paper clip to gently pull and push it back up to ensure both battery and cartridge are on the same level.
Letzte 24 Stunden: 13
Letzte 7 Tage: 31
Letzte 30 Tage: 126
Insgesamt: 2,822
