Zum Hauptinhalt wechseln
Reparaturanleitungen, Demontage und Informationen zur Fehlerbehebung für die dritte Neugestaltung des beliebten Mac mini Small-Form-Factor-Desktop-PCs von Apple, der im Oktober 2024 auf den Markt kam. Mit M4- und M4 Pro-SoCs und mindestens 16 GB Unified Memory.
How could I extend the power button cable?
I am working on an application that would involve me needing to extend the power button as the Mac Mini would be unreachable. Can you help me identify the power button clip and a potential way to extend the cable further?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Has anyone found what connector is used? If we knew what connector was used (and could get a couple) It would be easy to wire an extension and move the power button wherever.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Depending on what your application is, I’m assuming it’s to restart as the process hung. If that’s the case then just leverage the AC power cord by placing a line switch within its path, as an example a power strip. If the application is just doing a presentation type of loop that would work. You could also setup a watchdog process from another system to manage the power strip if it has a remote control option.
War diese Antwort hilfreich?
Bewertung 1
@matthewtietje if by power button clip you are referring to the connector, we don't have that information just yet. Just like all of those connectors you can most likely remove it from the actual cable. We would need to see a close up of that connector to determine how to take it off. After that its straightforward, just extend the wires but either or using a cable connector to connect a longer cable (however long you need). Then connect a SPST normally open pushbutton switch to the terminals of the extension.
Bewertung 0
1 Kommentar:
Thanks. You can see the cable being unclipped in the teardown. Hopefully someone will identify it in the near future!!
von
Antwort hinzufügen
matthewtietje wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 29
Insgesamt: 800
