Bogs then stops at full throttle
Okay so here’s what I’ve done.
- Compression 110
- Muffler and screen cleaned inside the muffler to the cylinder. Carbon free now
- Installed a new carb fuel filter
- Installed a new spark plug
- Adjusted the screw under primer bulb worked with all adjustments to flow were the same unless I closed it up then it died no pulling needed. As I said when you open it up it sounds and performs the same idles good throttle up head spins for a second bogs down stops
I can not figure this out it takes 5 pulls to achieve 110 compression. Is my motor burned up or what? It’s starts will stay running sounds good
Ist dies eine gute Frage?
Bewertung
0
