Zum Hauptinhalt wechseln
Repair guides, disassembly, and troubleshooting information for the fourth generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-040.
How do I tear it down
I need to know how to test it down
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi!
I think the most easiest way is to follow this guide: DualSense Kontroller v2 Hauptplatine tauschen
This basically tells you how to get to the last part. I know this is for the V2 controller instead for the V4, but the process is almost the same.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
what is the diffrence bertween the v2 and the v4 coontroller?
von
Hi!
Minor differences. Just some other parts are used from another brand. Like the triggers and rubbers are slightly improved. No big changes.
von
Thats wrong. The whole motor/shoulder trigger assembly is different. There are no screws on the front side (where the buttons press against the board) and no metal axle for L2/R2 also the flex-connectors are just 3 pins
von
Hi! I'm sorry! You are correct! The difference between the V1 and V2 aren't that big. Later on they did start with the 3 pins! My appologies!
von
Hilfreichste Antwort
V4 has 4 wires instead of 2. also the flex cables are smaller.
Bewertung 3
Antwort hinzufügen
Tavin Bauerle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 78
Letzte 30 Tage: 352
Insgesamt: 6,095
