Zum Hauptinhalt wechseln
My speaker doesn’t work after using headphones.
How can use a headset disrupt speaker even after disconnecting the headset?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @debraramer
It could be a sticking contact inside the headphone socket on the keyboard.
When you plug in a set of headphones it causes a contact inside the socket to operate and this sends a signal to the CPU on the control board to mute the audio to the speakers and to turn it on to the headphones. When you remove the headphones the contact releases causing audio to be restored to the speakers and to be cut off to the headphones.
Try inserting/removing the headphones a few times and check if that resolves the problem.
If no good then the keyboard will have to be opened and the headphone socket checked and possibly be replaced.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
This is pretty much what the problem was. I had just brought home the used piano and we were trying it out before bed. I plugged in the headset. I walked away. Then a bit later my husband unplugged them to check out the piano. He didn’t notice the adapter for the headset was left in the piano. I didn’t realize the headset had an adapter on it when I plugged it in. So we thought the piano broken. I sent a text to the previous owner the next evening (it was too late that night.). She told me about the adapter. I removed it & the piano is back in service.
von
Antwort hinzufügen
Debra Ramer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 255
