Zum Hauptinhalt wechseln
The Xiaomi Redmi10 5G is an entry level 5G Android smartphone which was released in March, 2022. It offers a 6.58" IPS LCD, a 5000 mAh battery, a 50MP main camera and runs on a MediaTek Dimensity 700 chipset.
Mengapa baterai cepat boros Why does the battery drain quickly?
Translation Indonesian - English
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
@ilhamnurfatin check your settings first. There are battery saver settings. You also want to make sure that you have updated your software, since sometimes bad firmware can be causing this. If none of that works you want to change your battery and then re-evaluate. since iFixit does not yet have a specific guide for this, use the one from here It was written in Spanish so use a browser that does the translating for you, if needed. Batteries are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@ilhamnurfatin periksa dulu pengaturan Anda. Ada pengaturan penghemat baterai. Anda juga harus memastikan bahwa Anda telah memperbarui perangkat lunak, karena terkadang firmware yang buruk dapat menyebabkan hal ini. Jika tidak ada yang berhasil, Anda perlu mengganti baterai dan mengevaluasinya kembali. Karena iFixit belum memiliki panduan khusus untuk ini, gunakan panduan dari sini Panduan ini ditulis dalam bahasa Spanyol, jadi gunakan peramban yang menerjemahkannya untuk Anda, jika perlu. Baterai tersedia di banyak toko daring.
Saat Anda menggunakan ponsel, ambil banyak gambar. Setelah selesai menggunakannya, ambil gambar tersebut dan buat panduan untuk iFixit. Panduan ini akan membantu orang lain yang memiliki perangkat dengan masalah yang sama seperti Anda. Membuat panduan ini mudah dan menyenangkan. https://ifixit.com/Guide/new Komunitas iFixit akan menghargai ini.
Perbaikan adalah Perang terhadap Entropi!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
14. Ilham Nurfatin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 371
