How do I fix not being able to hear out of one ear?
Ist dies eine gute Frage?
Hi Audra,
First step is to figure out what the problem is. Assuming you're connected by a cord, you'll want to eliminate that as the source of the problem first, either by trying the cord on a different device, or using a different cord. If that doesn't help, then it is most likely a problem internal to the headphones.
In most headphones the circuit boards and controls are on one side and a pair of wires runs through the headband to the speaker on the opposite side. That would be my first suspicion, especially if the side that doesn't work is opposite where the input plugs in. Any time you have wires that are in a position to be bent constantly, there's the possibility they will eventually break, and with the foldable Solo headphones that seems like almost a guarantee.
Here's a video showing a pair of your headphones being repaired due to exactly that scenario; a broken wire on the right side where the wire gets flexed constantly. He shows how to take it apart to get to the wire, but be aware that fixing it will require some soldering so hopefully that's something that you can do.
HOW TO FIX BEATS SOLO HEADPHONES: speaker no audio sound not working - YouTube
Good luck and let us know what you find and how it all turns out for you!
War diese Antwort hilfreich?
how to fix my beat solo force one side it works, but the other side doesn’t. How much is it going to be to fix it?
Byron, if you're looking to hire someone to fix it for you, I'm afraid you're in the wrong place. iFixit is a resource for people to enable people to repair their own devices rather than pay a shop to fix them. As such, we can try to help you diagnose the problem with your headphones and give you suggestions and methods to fix it, but that assumes you want to do the work yourself. Doesn't sound like that's the case for you, so all we can suggest is for you to search out local repair shops or online services that accept mail-in repairs.
If you want to try, view the video I posted already and see if you can locate any broken wires inside; as I said that's the most likely scenario.
Likewise, we can't really tell you how much it's going to cost since we assume your own labor is free for you; in that case it would only be whatever the price of any tools and/or parts you need to buy come to.
Past month been trying to connect still not working
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 81
Insgesamt: 1,526
