Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für die 2020er Neuauflage des MacBook Air. Erschienen im März 2020
Replaced battery not charging
My macbook air would not stay on unless plugged in and also said service recommended, so I decided to replace the battery. I followed all the steps to do so and was successful. My macbook now turns on, has a charge, and no longer says service recommended, but when plugged in there’s no indication that it’s charging or even connected to a power source. I tried resetting my SMC as advised online, but no luck. Should I now look into replacing my usb-c board, or is there another solution I could try first?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Let’s get a better view of things install this gem of an App CoconutBattery take a snapshot of the apps main window and post it here so we can see things.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
I added a screenshot to my original post.
von
@huntermarshall - Let’s let it charge for a good 6 hrs and then take a fresh CoconutBattery snapshot. This time let’s do the snapshot with the charger plugged in as we do need to see if the charger is charging.
von
that was taken with the charger plugged in. that’s what makes me think it’s the usb-c board, but in reality i have no idea about any of this.
von
Antwort hinzufügen
Hunter Marshall wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 245
