AMD RX 570 not booting. Voltage measurements included
Hey all, I've been trying to fix a XFX rx570 XXX edition 8gb. Keep in mind I've no knowledge so I've been doing this using tutorials. Any help is appreciated.
8pin connector led is open when pc boots, but nothing else happens (no image).
Fans don't spin.
Everything below is based on this video: https://youtu.be/2Yz7HfzggYc?si=UM8VOndm...
PCIe pins are all ok. They have similar resistance and not one is faulty. PCIe capacitors are all ok also, they have similar resistances.
12V pin is ok. 3.3V is also ok.
No visible damage/burnt components.
I booted it with the heatsink unscrewed to check voltages and here is what I gathered. Everything below is based on this video: https://youtu.be/5oD69tIrU7c?si=cQbnSDhl...
GPU core doesn't heat up at all. Stays cold.
12V voltage is ok (C157, C151).
3.3V voltage is ok (next to C157, C151).
At the 5V regulator on the back on the 3 legs I read 2.5V, 3.3V, 12.V and opposite of them I read 3.3V. Didn't read the suppossed 5V.
At the 1.81V on the back I read 1.81V. One thing I noted was when I read the voltage, the fans spun for a split second.
Display rail read 0.92V
VDDCI/memory controller read 0V
1R0 (memory) read 0V
GPU read 0V
Things I tried that I am not sure I did correctly:
Continuity test on 8 pin connector socket.
Resistance measurement on the regulators on the back of the card.
Thanks!
Update (04/10/26)
At the 1.81V on the back I correctly read 1.81V. One thing I noted was everytime I touched the probe on it to read the voltage, the fans spun for a split second.
GPU read 0V
Below is the full card pictures
Ist dies eine gute Frage?
3 Kommentare
Have you got any photos of the card? Are there any obvious damage to the card (ie. missing/burnt components)?
von honakrisi
Hi! Id lost access to this account, but got around to posting more info just now.
von harrishal776
@honakrisi he mentioned that there was no visible damaged components
von Cactus12
