Zum Hauptinhalt wechseln
Modell A1502 / 2,4, 2,6, oder 2,8 GHz Dual-Core Intel Prozessor / Erschienen im Oktober 2013
My beloved MacBook Pro is getting old.
Hi!
My beloved MacBook Pro 2013 prime is at its end, but I refuse to upgrade due to the quality of my computer.
I use my laptop for day-to-day things. Over the last couple years, I have had to strategically download and delete software depending on what I want to use my laptop for.
I love playing Sims 4- if I have the Sims software on my laptop, I cannot have anything else downloaded.
I had to delete the game when I decided to go back to school and was using online education platforms.
When using detailed interactive websites such as Canva, my computer struggles to keep up and the fan will begin to run at full speed.
I'm guessing it's to do with processing power, memory and just it's age.
The battery is good enough that it doesn't worry me too much. The laptop battery does drain if I'm doing a lot on the laptop, but I'm typically at home anyway and it's on charge.
To give my laptop a new life, what products should I update? The processor, memory, battery?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
I gave my old iMac a new life by using OpenCore Legacy Patcher. It's worth the effort, give it a try.
War diese Antwort hilfreich?
Bewertung 0
"What products should I update? The processor, memory, battery?
Unfortunately the only things that you can "Upgrade or Update" Are the SSD & The Battery as the CPU & RAM are soldered onto the board and cannot be removed or replaced easily. The last supported OS is 11.7.10 Big Sur. If the laptop is running a bit slow then maybe it is time for a clean install to freshen it up. Canva can be downloaded from here although it still needs a log in to fully function I think it may help improve the experience. These are great MacBooks and I think they are still very usable.
Bewertung 0
Antwort hinzufügen
Melanie Hartshorne wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 174
