Lenovo Ideapad Yoga 11S - fixed it so much it won't start...
I have one of those situations where you fix one thing and break something else in the process.
I have an old Ideapad Yoga 11s which would only work when plugged in, i.e. the battery didn't hold charge. So I bought a new battery. At the same time I bought a RAM upgrade from 4GB to 8GB. Installed them both fine. Unfortunately in the process of disassembly I damaged a couple of the ribbon cables (FFC). The laptop would boot but the screen wasn't working. Connecting it to an external display I could see it was otherwise working, the new RAM was recognised and the new battery was holding charge.
Getting hold of replacement FFCs is tricky but I realised that rather than searching for a specific part number which is hard to get, you can just get generics. FFCs are just defined by the number of pins, the pitch or distance between the pins and the length of the cable. Might be obvious to you guys but took me a while to figure out! So I got some of the right spec to replace the ones I'd broken, and put them in the laptop.
However now it won't start at all any more - no POST or BIOS never mind booting the OS, nothing on screen or an external monitor. I'm not sure what could have happened since the last time I looked at it as I was just waiting for the FFCs. Initially the power light was flashing orange, so I plugged the laptop in and after a while the light changed to white but still flashing, which apparently means it's in sleep mode. I've tried all the suggestions I could find to get out of sleep mode: remove charging cable, remove battery, remove RAM, hold power button for 1 min, replace what you removed then try again. Nothing. Also, initially the fan was on all the time and at some point in my troubleshooting it switched off and now it's off all the time.
Bit of a mess... any ideas?
Ist dies eine gute Frage?
