Zum Hauptinhalt wechseln
Erschienen am 21. Juli 2011. Core i5 oder i7 Prozessoren. Thunderbolt. Dieser Mini kann auch als Mac Mini Server gefahren werden.
Mac mini mid 2011 board in a PC case
I have a 2 Mac mini mid 2011( 1 with dual SSD drives and with default hard drive) and I was wondering do you think it is possible to fit the board( out of the outer case including the power supply)in a PC case.
for example My Idea is is to buy a computer case and put the Mac mini board in where PCI cards go?
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare:
What is your reason for doing ths? I can’t see this offering any benefit
von
To save space turn 2 into 1 because each Mac mini only has 4 usb ports each Mac Mac mini uses 2 USB ports 1 for the keyboard and 1 for the mouse leaving only 2 usable USB ports
von
@nathanlubbers - Sorry I still don’t follow you. Placing the Mac Mini logic board into a PC case won’t change the ports or offer other means of access (ports).
von
if it was possible it would just make cords more organized right now I have a USB hub Ethernet hub and a bunch of external hard drives in the same area as the computers
von
Einen Kommentar hinzufügen
2 Antworten
So instead of using a PC case, just create an open wooden shelf unit to hold the Mini and the drives. Remember a metal case will block the Bluetooth & WiFi signals.
Get some thin plywood and some square molding to create the lip to hold the shelves. Create the main box gluing and screwing to the blocks in the corners. Then measure the needed spaces you want for the drives and other stuff. Here I would only screw the blocks to hold the shelf so you can move it later if needed. You can also create a cross brace which you can mount the USB hub to so it’s out of the way and yet accessible.
That’s what I did with my 2011 which is my media server hosting my music and vids.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Could you post some pictures of your setup because it sounds to me almost like the setup I already have sitting loose on printer tray under my desk with thin back. also the antenna would not be in the PC case
von
@nathanlubbers - It’s buried in the back of a closet, and the unit is secured to the wall with some L brackets. I really don’t want to pull it out unless I need to change it which I haven’t in years.
it’s nothing that special, all I did was measure the unit and the drives and there width and depth and number shelves.
Nix the case it is not any better and the metal case will still block the signal. Think how light travels in straight lines that also holds true with radio signals.
von
@nathanlubbers - Maybe this will help, to control the cables I used zip ties anchored by using these to the wood with screws Saddle Type Zip Tie Anchors there are self adhesive types as well but they tend to fail over time. Between it all I think I spent three hours building the wooden shelf. It’s compact and uncluttered.
von
@nathanlubbers don't buy a case. It'll just box you in :-) Get yourself something like a PC testbench open chassis case rack. You got the dimensions for your boards and the peripherals. That will allow you to fully customize the rack and a clean cable management. It also does allow for some creativity when it comes to layout etc.
Bewertung 0
7 Kommentare:
OT, This is not a PC, it’s a self contained system onto its self. All you need is a flat surface or in my case I mounted a shelf system I made in the back of a closet to hold the system and the external drives. In my case it’s only a media server not running anything heavy. A PC case is not very practical and will interfere with the wireless connections. An open PC test bench used to test PCI cards won’t be helpful here. Some zip ties is what I used to control the spaghetti cables.
von
This is reason I asked about putting Mac Mini mid 2011 in a PC case is because I want to remove the logic board from the outer shell I would run them without a case but apple says they need a case to protect them from dust so I do like @oldturkey03 idea of using a PC test bench just to protect from dust
von
@nathanlubbers It's a totally open area which will decrease the accumulation of dust (at least no more dusty as the rest of your environment ;-) I've run many home computers even A-i-Ones and gutted laptops (no, not just PC's) that never went in a normal case. I've never had one overheat nor have I had a fan failure from to much dust etc. Nor have I had issues with WiFi, BT etc. The test bench is 100% customizable to meet your specific needs. Let your creativity be your guide. Be as Geeky as you wanna be :-)
von
@nathanlubbers - Have you reviewed the guides at all yet? You are attempting to re-engineer the case and the boards & power supply mountings which are not like a typical PC logic board which mostly follow an agreed upon standard. The volume of the space internally from a dust perspective is a non-issue unless you fully enclose the case, then only the air within it will circulate. But that then messes up the systems cooling as well as anything else in the case which needs cooler air.
Lastly the issue then gets down to your skill set, the risks and costs. It sounds like this is an important set of systems. Are you willing to mess up killing them or make it so you can’t recover back?
von
@nathanlubbers a testbench open chassis case rack is a perfect choice for this :-) It is not a case, it does not need to be enclosed and has a multitude of mounting positions that essentially can be used for any kind of circuit board (no, not cellphone or MP3 player etc.) It even works for xbox360 boards etc. Been there done that :-)
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
Nathan Lubbers wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 33
Insgesamt: 531
