Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
Battery iPhone 4s doesn't charge at all
Hi recently I open my iPhone 4S and now my battery doesn't charge instead of showing the lightning bolt icon indicating it was charging, it showed a plug icon. However, as indicated, the battery was continuing to run down so I tried all 3 cords, different outlets, etc. with the same result--the phone only showed a "plug" icon inside of the battery icon and the battery continued to lose charge. I tried turning the phone completely on and off but that only produced the same result. The battery inevitably lost all charge and my phone is now dead. Any suggestions?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I have the same thing with my iPhone 3GS i placet a new batery on it but it doesn't work.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
on the iPhone 4 check that the 2 tabs on the battery connector line up perfectly with the grooves on the phone. I missed this and my battery did not charge. When corrected all was good.
War diese Antwort hilfreich?
Bewertung 1
My Iphone was not charging before I replaced the battery. No change after battery replacement. Now what?
Bewertung 0
there isn't much to mess up on a 4s. The battery plugs into the connector and get screwed down with 2 screws.
Take it apart again and make sure you have everything lined up. If it is, its possible that you got a bad battery.
Bewertung 0
Antwort hinzufügen
Sergio Ruben Sanchez Balam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 4,440
