Zum Hauptinhalt wechseln
My CPU Start But In Monitor Display No Signal
cpu working but in monitor display no signal
Ist dies eine gute Frage?
Bewertung 4
5 Kommentare
My power supply is working but no sign of the computer is going to turn on
von
Hi @mahlatsedoeboy
Please confirm the make and model number of the motherboard?
von
mpg x570 - moba
von
@iantorchteeh
check if any EZ debug LEDs are turned on, on the motherboard.
Go to p.24 of the user manual to see where they're located on the board
von
thanks..new problem now is the USB port not active.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Possibly the RAM
War diese Antwort hilfreich?
Bewertung 1
first check your blue cable adapter connect to your graphic port, if still it doesn't work , then to my suggestion check your RAM , maybe there is dust inside the ram port or one of the ram is not working
Bewertung 0
1 Kommentar:
I have checked the RAM port but found nothing.
von
@iantorchteeh
If the PC is turning on with a display and Windows is the OS check that the USB Root Hub Power management setting "Allow the computer to turn off this device to save power" is unchecked.
Go to Device Manager¹ → Universal Serial Bus controllers → right click on a USB Root Hub entry in the list → Properties → Power Management → Uncheck the setting → OK.
Do this for all the Root Hub entries listed under the category.
Once completed, close any open windows and then restart the PC in the normal manner and then check if the USB port works OK.
¹ To get to Device Manager in Win10/Win11, press the Win key + x key (both keys together) and click on the Device Manager link in the menu box
Bewertung 0
Antwort hinzufügen
Unknown User wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 66
Insgesamt: 1,131
