Zum Hauptinhalt wechseln
The Samsung RF28HDEDT is a 36-inch French door refrigerator with a 27.8 cu. ft. total capacity, featuring a twin cooling system, LED lighting, external digital display and control, and a filtered ice maker. Its design includes a stainless steel finish, recessed handles, and hidden hinges.
No power to Refrigerator
We lost power to whole house today for about 10 hours, once restored refrigerator does not come back on. Any ideas what to look at?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @kayjordan
Are the lights working in the refrigerator?
If they're not working, then if you've proven that there's power available at the wall outlet where the refrigerator is connected, check if the 250V 10A glass fuse on the EMI filter board in the refrigerator is OK and not blown.
Below is an image showing the fuse on the board. It would be cheaper to replace the fuse than to replace the whole board but you would have to solder it in. If you wish to change the board, search for Samsung DA27-00022B.
If the lights are working, then it may be a problem on the control board.
(click on image)
Removes impurities from the refrigerator's coils to maintain proper airflow and efficiency. Bild
Produkt
Samsung Refrigerator Coil Filter - DA27-00022B
$125.99
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Kay Jordan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 27
Insgesamt: 752
