Zum Hauptinhalt wechseln
The Craftsman 315.228390 table saw is a stationary saw with a 10-inch blade, adjustable tilt, and a 13 amp motor. This page provides repair and additional information about its features such as the precision ground cast iron table top, self-aligning rip fence, and enclosed belt drive system.
Drive Belt install instruction
Help on adjusting the Drive Belt.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @peyton83066
Here's the owner manual for the table saw that may help.
Go to p.24 to view the procedure to install the drive belt and belt guard.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I know how to install the belt. I would like a step-by-step way on how to adjust it. When I raise the blade all the way up, the motor is twisting, V-belt is rubbing. Thanks
von
@peyton83066
The only adjustment is described on p.24 when installing it.
Check the Mounting the motor procedure on p.23 to make sure that the motor is secure
von
Antwort hinzufügen
Peyton wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 115
