Zum Hauptinhalt wechseln
The Sharper Image Literati is an e-reader with a key board, model number 1637287. The Literati has a 7 in. full color screen and the name of the e-reader "Literati" is inscribed above the screen.
What are the specs for a replacement battery for my Literati?
I measured physical dimensions of approximately 120.97mm x 58.6mm x 4.1mm. The markings on my battery are exactly the same as shown on the guide for replacing the battery. Besides looking for something in the 2750mAH range (how much higher can I go?), what voltage should I seek? Thinking 3.7V
Just wondering if there are other specifications I should pinpoint.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @lkvee
With the battery in its normal position in the tablet, measure how much space there is available on either side. It looks like there's space available in the length
I've found a battery size that might fit.
Looking for a 4060120 3.7V LiPo battery gave results as shown in the link.
The way to interpret the code on a battery is as follows:
4060120 = 4.0mm height¹ x 60mm width x 120mm length.
¹The decimal point is not shown in the height measurement in the dimension specifications printed on a battery
If there is space to accommodate the width i.e. 60mm then ensure that you get a battery with a 3 wire connection. The 3rd wire is normally used for temperature monitoring of the battery, especially when charging and if you get a battery with only a 2 wire connection i.e. red and black, you may have problems with it charging correctly and also getting too hot when it is being charged.
You can get a battery with a higher milliAmpere (mAH) rating as this means that the battery will last longer before it needs recharging, but it also means that it will take longer to fully charge, but ensure that it has the 3.7V voltage rating and not higher (or lower).
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
lkvee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 133
