Hi @yonisackstein
Here's the parts list that also didn't help.
The transformer Vulcan part number is 851800-773 but I've had no luck finding it using the part number.
It's a Step-down 208/240 12v transformer
Hi @yonisackstein
I think I found one but it may depend on the physical size and the connection type of the original as to whether it fits OK. Electrically it has the correct specifications.
You can use the 240V input connection i.e. 240V + Com, only if that's all you need. Insulate the 208V connector using electrician's tape to prevent it coming into contact with anything as it might be "live" when the 240V is conncted to the other termnals
Search online for Moffat Transformer 208/240V X 12Vac Sec 15Va M234429 to find suppliers that suit you best. (supplier examples only)
Just wondering, how old your oven is?
Looking at the image you posted in an earlier question you asked for the same oven model transformer, it shows that the transformer has a 230V input only yet the parts manual I linked above shows that it has two voltage inputs i.e. 208 and 240V for models prior to and since 2010.
Maybe the original transformer is not available anymore and the parts list shows a compatible replacement (also the specifications) or they've changed the power requirements.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
3 Kommentare
@yonisackstein it will help if you can let us know the dimensions for the transformer. I wonder if the one from a VCH 8 would not fit
Length (inch)7.3
Width (inch)5.35
Height (inch)5.2
Part number for that is 00-960751
von oldturkey03
Thank you so much for your help. So what do you suggest as best way forward ?
von Yoni Sackstein
[image|3532899][image|3534409][image|3534410]
This is what landed up buying from Amazon. The Vulcan guy said need 208/240 also that’s what it’s shows on top of the oven but the original transformer that broke shows 230. Does this make sense e
von Yoni Sackstein
