Zum Hauptinhalt wechseln
The DJI Mini 2 is a small drone that was made in 2020 by DJI. The DJI Mini 2 has 4K/30fps video and 10km 720p/30fps video transmission.
My DJI mini 2 controller won't charge
My DJI mini 2 controller will not charge
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
If your DJI Mini 2 controller isn't charging, first check that you're using the correct charging cable and power source, then try using a different cable and charger to see if the issue persists; if it does, the problem might be with the controller itself and you should contact DJI support to potentially send it in for repair.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
this forum is called " I fix it" not "DJI repair shop fixed it" :-)
von
This is somewhat outdated now I guess, but did you fix it in the end? If you're a technician you've probably taken it apart?
Bewertung 0
Antwort hinzufügen
Timothy Howard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 183
