The phone stop's charging at 75 percentage
Why is that the phone stop's charging at 75 percentage it won't increase until i turn off the phone then it continue charging
Ist dies eine gute Frage?
If your phone stops charging at 75% and only continues charging when you turn it off, this is likely due to a built-in safety feature to prevent overheating, which is triggered by heavy usage while charging; when you turn off the phone, the heat generated reduces, allowing the battery to charge further.
Key reasons why this might happen:
War diese Antwort hilfreich?
Change charging port.👍100%
Another check setting battery safety enable
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 48
Insgesamt: 945
Bagaimana cara supaya baterai hp saya tidak gampang lobet meski msh d 75%...
von Muhamad Rafli
Garam hora ha mobile
von Adil
