To those of you who have no backlight on an LED lit macbook -
The problem is most likely related to the WLED driver on the logic board not supplying power. Power output from the WLED driver ranges from something like 18-26 volts. most other circuitry on the board runs at 12v or less, so liquid spills do not damage other parts on contact.
your lvds cable is most likely fine. there is a fuse on the logic board that runs the WLED driver. it is normally located close (within 2cm) of the lvds connector, and is a 0402 package (the smallest on the board, will look like a surface mount resistor or capacitor). on my macbook (nonpro, 13.3") it was a brown fuse with a small white dot in the center. can also be black, or have an "f" in the center. measuring both sides of this fuse with the macbook power on should read 12v. if not, the fuse is bad.
you CAN just remove the fuse and close the circuit with a blob of solder, however if there is still a short in the system (remaining traces of liquid spill, residue, etc) and you short this fuse, you will destroy the WLED driver chip. these need to be replaced by a micro electronics professional, with a hot air gun and microscope.
your best bet is to find someone good at soldering (very, very small) and order some replacement 0402 package fuses and solder in a replacement.
if the fuse is good, pin1 of the wled driver should be receiving ~3v to power up the wled driver. if fuse is good and still no output from wled driver, then the wled driver itself is most likely damaged.
you can search around the net, there are a few chinese forums with schematics and pictures of the macbook logic boards to help you with this.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
6
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
4 Kommentare
Wait for an answer from leemise or bac, they're the experts on this type of problem.
von mayer
has anyone fond the solution yet? i have the same problem...
von palokiller
I'm having the same problem, has anyone resolved where to find the specific LVDS cable?
von Ben
I am in the same situation.
Although, I spilled water on my Macbook Unibody (not the newer 'pro' editions). Everything works perfectly, keyboard, trackpad, keyboard backlights, sound.... I can also see the screen under a bright light, or all works perfectly when I plug it into a monitor.
My screen has been replaced but still no avail, The company that tried to fix it said it was a problem with my Logic Board.
It's so annoying that my whole laptop is working but its just the %!*# light that isn't working! And the only option is a new Logic Board apparently.... Might as well get a new laptop for that price...
Has ANYONE found ANY other solutions?????
Please let me know, I would really appreciate it if you took your time to help!
Thanks!
von MacBook
