Is a 52W compatible if my device has an original 56W
Is a 52W battery replacement compatible if my original battery was a 56W
Ist dies eine gute Frage?
The 52w will work but will not allow you as much runtime as the 56w
War diese Antwort hilfreich?
I agree with Thomas, assuming all other factors are compatible, if the wattage is the only difference then the length of time it will run should be the only effect you see - well, it may take a tiny bit shorter time to charge - but doing the math the 52W has about 93% of the power of the 56W. So if the original was rated to run at two hours (I'm making this number up), then the replacement would run for an hour and 51 minutes.
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 30
Insgesamt: 132
As long as the replacement battery is a direct fit, it should not make any difference.
von F Dryer
