Zum Hauptinhalt wechseln
Repair information for the SteelSeries Arctis Pro wireless headphones. Released in March of 2018. Model number: 61743.
How can I remove this melted plastic on my headset?
Hi, I had my Arctis Pro Wireless for 2-3 years now and the hinges died on me completely at this point. Headset is super loose and I went ahead and bought a replacement part for the casing.
Now I ran into this issue, I don’t know how to remove this “melted plastic” (might be glue i’m not too sure) that they have inside the headset to lock in the outer shell. I have to remove this to be able to transfer the battery port from the old casing to the new one.
Any recommendations would be fantastic.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
They appear as factory plastic welding, melting plastic to permanently weld parts together. If you are sure they are preventing separation of parts, you can use electronic wire cutters to snip off plastic until separation occurs. After reassemby, either melt the plastic to weld things together, apply plastic cement compatible with the plastic or epoxy (JB Weld). There are 5 minute epoxies for faster bonding if JB Weld takes too long to harden (overnight).
von
@notbroken hey man, i’ll it a try. I was using an exacto knife earlier but it was just too hard to cut with it. Thanks for the reply.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I was able to get rid of them and open the back lid, I had to use a “Nail Clipper Plier” and just break them completely one by one. Took me 20 minutes but it’s done now.
War diese Antwort hilfreich?
Bewertung 1
An exacto knife is too pointed.
You need something rigid with a wider flat surface like a flat head screwdriver or any similar object.
Wedge it under the melted ring and gently twist. The wide surface often breaks off as the melting process made them quite brittle.
You just need to figure out a way to secure the replaced part back.
Bewertung 0
Antwort hinzufügen
Night Walker wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 218
