Zum Hauptinhalt wechseln
Repair guides, disassembly, and troubleshooting information for the fourth generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-040.
How do I fix my stiff thumbstick?
When turning the thumbstick in any direction, once letting go, it does centre itself and stays turned the direction i turn it to.
Ist dies eine gute Frage?
Bewertung 2
4 Kommentare:
Hi!
Which thumbstick is it?? I would replace the joystick, this will most likely fix it.
von
The Left thumbstick
von
How to fix stick drift
von
You can try this one first: DualSense V2 Controller Stick Drift Reparatur
Otherwise you need to replace the whole joystick: DualSense Controller v2 Joystick tauschen
Good luck with the repair!
von
Einen Kommentar hinzufügen
1 Antwort
Common issues related to a stiff thumbstick include dust or dirt getting into the DualSense (PS5) Controller V4, internal misalignment or stick drift issues. Here’s how you can fix it:
Check for Dirt & Debris
Move the thumbstick in circles and see if anything sticks.
Then shoot a can of compressed air around the base of the thumbstick.
Clean edges having a soft brush or cotton swab using isopropyl alcohol (70% or better).
Reset the Controller
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
ecowarriors wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 49
Letzte 30 Tage: 204
Insgesamt: 3,157
