Zum Hauptinhalt wechseln
Das DS Modell ist die siebte Generation der Spielekonsolen von Nintendo.
Why does the power light turn green then orange then shut off?
I am currently fixing an old Nintendo DS. I had put in a battery and by the fact that the bottom screen flashed but the top didn't, I replaced the top screen ribbon. However, when I closed up the new shell (old one was destroyed) and put in the battery to try and power it, it didn't turn on at all other than the power going green, then turning orange then shutting off. Unlike before, the screen doesn't even flash. Any ideas as to what may be wrong?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi there!
This is strange. Did you double checked if everything is connected properly? How are the battery pins? Could you share some pictures with us regarding the motherboard? It’s most likely motherboard related..
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I have added pics to the post. If you'd like any more specific photos please let me know.
von
Thanks for the pictures! Everything is connected as it should be and can’t see any component that physically failed. Please check the fuses (labeled with F) with a continuity test. Also check the EM10 labeled on the motherboard. If all of them are fine, it’s easier to get a new motherboard… sorry.
von
Try this.
Orange LED turns on for 5 seconds then shuts off when plugged in
Bewertung 0
2 Kommentare:
I tried it and unfortunately it still didn't work
von
When I tried holding the power as I plugged it in, not did the orange light flash, there was at the same time a great light that flashes as well
von
Antwort hinzufügen
Nathan Cote wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 133
