Zum Hauptinhalt wechseln
Reparaturanleitungen, Support-Informationen und Fehlerdiagnose für das 13-Zoll MacBook Air vom März 2024 mit dem M3 SoC von Apple. Veröffentlicht am 8. März 2024, erkennbar an der Modellnummer A3113.
MBA battery charge drain with no activity
Yesterday I've noticed a strange thing with my MBA 13.6 M3. I usually when at home or don't need to move, I leave the magsafe attached and it will. be usually green. When I come back yesterday from work, I've noticed the green was orange and the battery was at 80%, but whan I closed the lid beafor go to work in the morning the battery was at 100%. I've waited until the battery comes back to 100% during this night and today I found the battery at 87%!
Why this occur?Is there something wrong with my MBA?
Update (02/14/25)
Ist dies eine gute Frage?
Bewertung 0
6 Kommentare:
It maybe slightly lower than the likely normal capacity for a new laptop, but this can be about normal. How long does it take to fully drain from a full charge?
von Teilen
I'm not sure about but it will mantain the charge for 1 day. Iusually leave the magsafe attached when possible so I've just used 33 cycles of charge. My forst MBP mid 2014 after the same time of usage had the battery a lot used but with more charging cycles
von Teilen
@ziobru ! day is way to less.... @danj thoughts?
von Teilen
@livfe it depends what usage I do. but I think it's ok for a laptop.?
von Teilen
@ziobru Yes, if your on it most of the day then you can expect the battery to drain faster, but if not used and the laptop was in sleep mode then overnight around 2% or a little more maybe.....
von Teilen
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
1 Antwort
Try to install coconutBattery and post a screenshot of the battery information and we can go from there. It maybe a good idea to also include the (About this mac, system report, power tab info) to compare side by side.
War diese Antwort hilfreich?
Bewertung 0
7 Kommentare:
posted the screen in the answer
von Teilen
my MBA was purchased in october 2024
von Teilen
@livfe - I would use use Activity Monitor to see what’s running. Either a process is running chewing power or there is a tracker running spying on you.
von Teilen
@danj Yes, I was going to get onto that, shut down the laptop and reboot it then open the Activity Monitor and let it be a few minutes then post a screenshot of what is going on.
von Teilen
@livfe - I would do a couple of hours with the log and even the power graphing setup is a second window side by side.
von Teilen
2 weitere Kommentare anzeigen
Antwort hinzufügen
B1P wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 342
