Zum Hauptinhalt wechseln
Reparaturanleitungen für die 3. Generation des 11" iPad Pro (Modellnummern A2377, A2459, A2301 und A2460).
Battery replacement for m1
Is the ipad pro 2018 and 2020 11inc battery compatible with 2021?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Over the years battery technology has improved! The iPad Pro 11" (2018) Battery is not as powerful as the iPad Pro 11" (2021, 2022) Battery. So while the batteries do look similar iFixit Store does treat them as different batteries. Also note the 3rd gen battery is a few dollars cheaper!
I would stick with the correct battery.
Here’s the guide iPad Pro 11" (3. Generation) Akku tauschen
Replace a 7869 mAh battery compatible with the 11 inch iPad Pro 2018 model tablet. Fix issues like a swollen or fast draining battery. 3.78 Volts (V). 20.72 Watt Hours (Wh). Battery Model #A2042. Part #020-02875, 020-02507. Bild
Produkt
$49.99
Replace a 7680 mAh battery compatible with the 11 inch iPad Pro 3rd Gen (2021) or 4th Gen (2022) model tablet. Fix issues like a swollen or fast draining battery. 3.76 Volts (V). 29 Watt Hours (Wh). Battery Model #A2369. Bild
Produkt
$59.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Mark laurence wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 41
Insgesamt: 934
