Zum Hauptinhalt wechseln
Der Ford Focus der zweiten Generation (Mk 2) wurde 2004 als Drei- und Fünftürer-Schrägheck sowie als Kombi-Variante eingeführt.
Problem with ac & heat with a part in the dash
There is a problem with a part behind the dash that stops heat and ac from working and I can’t afford $1200 repair. Help
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Boy, Rick, you haven't given us much to work with here.
Let's start with exactly what year and model/submodel Focus do you have? There can be significant differences between years and models that could easily affect our answers.
Next, I'm afraid we can't really tell what's going on from your description. Do you have a written estimate from a shop that gives a little more detail? Can you add a picture of the part that's broken, or describe it in more detail?
As I mentioned, we really have to have more to go on before we can help.
Basically you've told us that something's broke, how do I fix it, and that's all we know.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Here is the deal. The major labor is getting to the part. If you have the time and mechanical expertise, you may be able to fix it.
Here is the theory:
Heat works by passing engine cooling water thru a valve into a small radiator under the dash with a fan blowing air thru it into the duct work.
AC works by running a compressor under the hood and passing the coolant thru another small radiator under the dash, again with a fan to blow the cool air thru the duct work.
If neither heat nor AC work, you might have a problem with the control circuit, since they are basically separate systems.
You must start with some observational troubleshooting. "My car doesn't go. What's the problem?" == is not a good question!
Adjust all controls to determine exactly what each one does or does not do.
Does the fan turn on and adjust the fan speed?
Does the duct work controls direct the air to the correct outlets? Upper, lower, defrost
Do you get any heat when the temp gauge indicates the engine is up to normal running temp?
When you turn on the AC, do you hear the compressor clutch engage (under the hood). The engine should also change speed slightly. Ambient temp should be at least 60°F.
Some AC systems have a glass view port in the AC tubing to allow viewing the refrigerant movement and bubbles. If you have one, what do you see?
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I’m sorry. I was in the hospital and still am, when I posted this and I was confused. Here is more info. 2012 Ford Fusion SE 6cyl
3.0 flex
Vin 3FAHP0HGXCR259749
176,226 mileage title 4/3/23
The a/c wasn’t working so we went to YouTube. A very helpful fellow reached out numerous times. He said there was a part in the dash that went bad lots. There was no recall?? but the cost of replacement was over $1k because the dash had to come out. But he gave me a capacitor # and instructions. We placed it behind the glove box in the spot he detailed. It worked and we had ac for a few months. The battery went dead at winters start. When the battery was changed all of a sudden the defrost and heat stopped working. My son went back to the shop. The mechanic reached up under the dash by the accelerator pedal and the heater started working. Unfortunately my son didn’t see or ask what he changed. After winter the ac wouldn’t work. Then neither did the ac. It got dangerous this winter. Cont. next comment.
von
Cont….. The YouTube got gave me another fix. He said I could lift the door in the middle of the top of the dash. I could cut a hole on the back wall and access the part without removing the dash. The part twists in and out. He said I can find the best tool to reach in and remove the part and replace it with the new part. He said that will fix ac & heat for a few years at least. That was the original problem. Part went bad after a couple years. I don’t know why Ford never put a recall for this. If anyone has any suggestions or comments I’d appreciate it. In hospital I do not have access to my notes to contact my YouTube guy. Everything he suggested was right on and worked. Thanks in advance.
von
Antwort hinzufügen
Rick Rod wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 36
Insgesamt: 401
