Zum Hauptinhalt wechseln
The Gigabyte GA-990FXA-UD5 is a motherboard manufactured by Gigabyte. Released in 2012. Model number: GA-990FXA-UD5.
Why my computer is failing to start
My computer is failing to start my monitor keeps saying going to sleep
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
There may be a problem with the memory module. It is recommended to replace the memory module. If the cooling fan doesn't turn, it may be too dusty. You need to clean up the dust and then wipe the memory module with an eraser. If the situation is still the same, it is likely that the power adaptor does not work, or the motherboard may have been accidentally dropped and cannot be started.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Ashley Choto wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 71
Insgesamt: 548
