Zum Hauptinhalt wechseln
Repariere dein Samsung Galaxy Note20 5G mit diesen DIY-Reparaturanleitungen für Ersatzteile.
charging port, slow charge
phone charges slowly and total cuts the connection when plugged into my auto will come back on after unplug and re plug, sometimes have to do couple of times, also shows message 'trickle charge' changed cords (a couple times) it will charge but slowly
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@redeye13 sounds like either a bad battery or a bad charging board. This "after unplug and re plug, sometimes have to do couple of times" sounds more like the charging board. Replace one, then the other to narrow it down, or replace both and be done with it :-)
Since iFixit does not yet have a guide for this, use the Samsung Galaxy Note20 5G Disassembly & Reassembly instructions. Instead of a hot plate you can use a good hair dryer or a heat gun (low settings) to replace the screen
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Redeye13 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 10
Letzte 30 Tage: 19
Insgesamt: 169
