Zum Hauptinhalt wechseln
Troubleshooting, repair guides, user and service manuals for the Dell Inspiron 13-5300. The Dell Inspiron 13-5300, a lightweight portable 13-inch laptop.
1 Fragen Alle anzeigen
Laptop won't power on with new battery.
My Dell Inspiron 5300 (2019) was working, except when it was plugged in, it kept switching from battery to plugged in mode and eventually the battery died and I couldn't get it to recharge. I replaced the battery and now the laptop won't turn on. I've tried powering on the laptop with just the new battery, with just the power cord and with both the power cord and battery - nothing, the laptop won't power on. Suggestions?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi @gatlboy
Try a full power refresh in case the BIOS is corrupted preventing a normal start and check if that resolves the problem.
  • Disconnect the charger from the laptop if connected.
  • Open the laptop and disconnect the battery from the motherboard. (You don't have to remove the battery, just disconnect it)
  • Disconnect and remove the coin cell RTC battery from the motherboard
Here's the service manual for the laptop. Go to p.23 to veiw the procedure to remove/replace the RTC coin cell battery from the motherboard
When the RTC coin cell battery has been removed, measure its voltage. If it is <2.5V DC or if the battery is >4-5 years old, replace it.
  • Press and hold the power button on the laptop for a full 30 seconds and then release it.
  • Reinsert and reconnect the RTC coin cell battery
  • Reconnect the battery, reassemble the laptop, connect the charger and check if it turns on OK.
If the laptop turns on OK, there might be a message stating that the date and time are incorrect. This is normal as the BIOS has been reset back to default by the above procedure. Once the date and time have been corrected, the message won't appear the next time the laptop is started. Also if any user definable BIOS settings were changed by you to suit whatever system requirements were needed, they will need to be changed back again as well.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Gatlboy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 18
