Zum Hauptinhalt wechseln
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
My Xbox green light is burning but not connected to the TV
The xbox green light is burning but connected to the TV connected to the TV and connecting to the TV, but does not work
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hello Sheroz, I see that you’re struggling with your Xbox. Here are some things you can try:
—First I hope your green Xbox led isn’t burning because you will have bigger problems then.
—Try turning on and off your television, console and any other object that could interfere with the video signal.
—Check that your TV or display works with other sources?
—Try a different port on your television (if possible)
—Try connecting your console to a different display
—Try different cables
—Try a different port on your console
—Try different types of port on your console (if possible)
—If the two bullets before this don’t work, you may need to replace your HDMI port. HDMI port replacement
—Or you can power everything off for a day and see if letting things cool off will help
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Sheroz Abduhalilov wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 27
