Zum Hauptinhalt wechseln
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
My 360 started smoking out the back vents
I tried to hook up a 12 v power pack to it but when the power button was clicked it started to smoke. A voltage regulator was blown. Can somebody help me Id it?
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Console is still working or facing any issue? Did you tried another voltage regulator? I faced something similar with my PC and figured out it was because of cheap product.
War diese Antwort hilfreich?
Bewertung 0
5 Kommentare:
The thing is I don’t actively have the original power pack but tried to hook up an Xbox 1s psu to it
von
Also the regulator started to crumble apart
von
I opened it and there is only one damaged component
von
Do you know where I could buy a new one?
von
Yes I guess all these chinse stuff is the issue. Go with the original one atleast you will be safe check this, this is original my Microsoft but do cross check before ordering
https://www.walmart.com/ip/Restored-Xbox...
von
The regulator is a 5 pin over by the power connection port under the hard drive. It is 1.8 volts
Bewertung 0
Antwort hinzufügen
Johann Winter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 68
