Zum Hauptinhalt wechseln
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
Power steering isl going out
2009 ford f150 fx4 power steering belt and pump constantly buying a new one what’s causing them to keep going out
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@jennyevans let us know exactly what happens to your pump. Let us know what symptoms it gives you. Those pumps are actually fairly bulletproof. Let us know if your F-150 has a separate steering fluid cooler. I wonder if there is an issue with the alignment of the pump bracket. Of course, you also want to inspect the steering lines and hoses for any kinks restrictions or other damage.
Here is the Ford F150 2011 2014 Steering Chapter from the workshop manual. It should help with the diagnostics of the issue. Let us know what you find out.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Jenny Evans wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 56
