screen filled with lines
Ist dies eine gute Frage?
@mickey53796 you're not giving us a lot to work with here. It will help if you post some pictures of what your screen actually shows. Bilder zu einer vorhandenen Frage hinzufügen
Connect an external monitor to your Lenovo and see if that shows a clear picture. If so, then the issue is most likely a bad LCD screen on your computer. If an external monitor shows the same lines then the issue is with your GPU on your motherboard.
Use this Lenovo Ideapad 110 14 15 Series Hardware Maintenance Manual to work on your computer (if you do need to change the LCD assembly etc.)
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 189
