Clicks are not registering
My mouse does not register clicks sometimes I have to apply to much force for a click to register
Ist dies eine gute Frage?
The switches inside that make up the mouse click function can get gummed up or fail. Since I don't know which mouse you have, all I can do is give you an example of the kind of thing you might have to do to either clean the switch or replace it. Here's a video for the B100 mouse showing how to open it up and lubricate the button switches with some WD-40.
Logitech B100 Switch Fix - Disassembly (click problem) - YouTube
That could be all that's wrong with your mouse, or it could be a failing switch or even a damaged finger mechanism. No way to tell without opening it up and taking a look. Replacing a switch would require some soldering if you feel comfortable doing that, but again we'd need to know your model number before we can make concrete suggestions.
War diese Antwort hilfreich?
I think u r right because one time i tried to clean it by blowing air and they seem to work fine after that . Also I will work on ur solution so that it never occurs again . Thankyou :)
Letzte 24 Stunden: 2
Letzte 7 Tage: 33
Letzte 30 Tage: 142
Insgesamt: 1,880
1 Kommentar
Which model of mouse do you have; there are several that fall under the "B" series and it is important to know the correct one.
von Jerry Wheeler
