Zum Hauptinhalt wechseln
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
My 3DS won't turn on
I have had this console for at least 8 months, and it died on me. It was working fine too before it broke. No blue light would appear when I pressed the power button, and when I charge it, the orange light appears, then later dies after a few minutes. The weirdest thing about this error is when every once in a while, the New 3DS would boot on, and the battery would say that it's 3 bars full. Then after like 10 minutes, it shuts off automatically. What can I do to fix this issue? My DSi also died the same way, before the 3DS broke. I even changed the battery, and that still doesn't fix it. I want to deconstruct the 3DS, and see what's wrong, but i'm scared that i'll break the console. Is there a solution to fix this issue, or do I have to buy another one?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
There might be a faulty chip or component on the motherboard. Check if the old battery works on another 3DS. If it does, its a problem with the motherboard. If you're too scared to fix it, try get as much data off the 3DS onto an SD card and send it to someone to try repair it. If that doesn't work then you will need to get a new one. I wish you luck on fixing the 3DS.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Joshua Pangan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 9
Letzte 30 Tage: 31
Insgesamt: 190
