Zum Hauptinhalt wechseln
Why does my phone not want to charge and the power button doesn't want
It just switched off and doesn't want to switch on again, it doesn't charge at all
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
It sounds like your phone may have a power-related issue. Here are some possible causes and troubleshooting steps to try:
1. Check the Charger and Cable
  • Try a different charging cable, adapter, and power outlet to rule out a faulty charger.
  • If possible, use a different phone to see if the charger works.
2. Perform a Forced Restart
Since the power button isn’t responding, try this:
  • Press and hold the Power button + Volume Up for at least 30 seconds to force a reboot.
3. Inspect the Charging Port
  • Use a flashlight to check if dust or lint is blocking the charging port.
  • Clean it gently using a toothpick or compressed air.
4. Try Charging for a Longer Time
  • Plug in the phone and leave it charging for at least 30–60 minutes even if there’s no response.
  • Sometimes, the battery is deeply discharged and takes time to show signs of life.
5. Check for Overheating or Water Damage
  • If the phone recently overheated or got wet, it might need professional repair.
  • Look for moisture inside the SIM tray as a sign of liquid damage.
6. Boot into Recovery Mode (If Possible)
  • Hold Power + Volume Up until the Huawei logo appears.
  • If the recovery menu shows up, try "Restart" or "Wipe Cache Partition".
7. Hardware Issue?
If none of these steps work, the issue could be a dead battery, faulty charging IC, or motherboard failure. In that case, a repair shop might be the best option.
Let me know if any of these steps help! 😊
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Desiree Arnolds wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 181
