Zum Hauptinhalt wechseln
Camera works perfectly, but screen stays black
Fotografieren funktioniert problemlos, Blitz und Video auch, aber der Bildschirm bleibt seit letzter Woche schwarz. Lohnt sich bei einer D3500 das Einschicken zur Reparatur?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@thomassterr "Lohnt sich bei einer D3500 das Einschicken zur Reparatur?" Never! :-) They just want your hard earned money! Remember that the iFixit mission is to empower YOU to repair your own device. Repair will keep your hard-earned money in your pockets instead of further feeding the Profit-before-People (Planet) machinery.
With that said, iFixit doesn't yet have specific guide for the LCD replacement, which I am certain is the issue with your camera, based on what you have told us. Sometimes it is the backlight that has failed, sometimes it is the actual LCD. Turn your camera on and then in a darkened room use a flashlight and shine the beam at an angle against the screen. See if you can make out you menu etc. If you do, then it is your backlight that has failed. If you do not see anything it is most likely your LCD. To replace the actual LCD use something like this video and combine that with this guide https://de.ifixit.com/Anleitung/Nikon+D3.... Yes, it is a slightly different camera but the steps are pretty much identical. The only thing that might be different are some of the i the screw locations as well as the flex cables. Juist take your time and be organized when you work on this so you do not get ahead of yourself. It is really not that complicated. Replacement LCDs are readily available at places like this and many others. This is an example only and not an endorsement. The cost for the screen will only be a fraction of what the repair shops will charge you.
Now , if and only if a new LCD should not work either, then the issue could be related to the connector or circuit boards, which is unlikely since your camera still works. Let us know what you find out.
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@thomassterr „Lohnt sich bei einer D3500 das Einschicken zur Reparatur?“ Niemals! :-) Sie wollen nur dein hart verdientes Geld! Vergiss nicht, dass es die Mission von iFixit ist, DICH zu befähigen, dein Gerät selbst zu reparieren. Durch die Reparatur bleibt dein hart verdientes Geld in deinen Taschen, anstatt die Profit-vor-Mensch (Planeten)-Maschinerie weiter zu füttern.
Allerdings gibt es bei iFixit noch keine spezielle Anleitung für den Austausch des LCD-Bildschirms, bei dem ich mir aufgrund deiner Angaben sicher bin, dass es sich um das Problem bei deiner Kamera handelt. Manchmal ist es die Hintergrundbeleuchtung, die ausgefallen ist, manchmal ist es das LCD selbst. Schalte deine Kamera ein und leuchte dann in einem dunklen Raum mit einer Taschenlampe schräg auf den Bildschirm. Schau, ob du dein Menü usw. erkennen kannst. Wenn ja, dann ist die Hintergrundbeleuchtung ausgefallen. Wenn du nichts sehen kannst, liegt es wahrscheinlich an deiner LCD. Um das LCD auszutauschen, verwende etwas wie dieses Video und kombiniere es mit dieser Anleitung https://de.ifixit.com/Anleitung/Nikon+D3.... Ja, es ist eine etwas andere Kamera, aber die Schritte sind so ziemlich identisch. Das Einzige, was anders sein könnte, sind die Positionen der Schrauben und der Flexkabel. Nimm dir Zeit und sei organisiert, wenn du daran arbeitest, damit du dich nicht überschätzt. Es ist wirklich nicht so kompliziert. Ersatz-LCDs sind leicht erhältlich bei like this und viele andere. Dies ist nur ein Beispiel und keine Empfehlung. Die Kosten für den Bildschirm betragen nur einen Bruchteil dessen, was dir die Reparaturwerkstätten berechnen werden.
Wenn auch ein neuer LCD-Bildschirm nicht funktioniert, könnte das Problem mit dem Anschluss oder den Platinen zusammenhängen, was aber unwahrscheinlich ist, da deine Kamera noch funktioniert. Lass uns wissen, was du herausfindest.
Während du an deiner Kamera arbeitest, mach viele Fotos. Wenn du damit fertig bist, nimm diese Bilder und erstelle eine Anleitung für iFixit. Das wird der nächsten Person helfen, die ein Gerät mit den gleichen Problemen hat wie du. Es ist einfach und macht Spaß, diese Anleitungen zu erstellen. https://de.ifixit.com/Guide/new Die iFixit Community wird das zu schätzen wissen.
Reparieren ist Krieg gegen die Entropie!
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Thomas Sterr wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 98
