Zum Hauptinhalt wechseln
Released 2021, December 31 176g, 8.2mm thickness Android 11, MIUI 13 128GB/256GB storage, no card slot
Bluetooth keine 30cm Reichweite
Bluetooth Funktion (Übertragung) ist sehr schlecht. Sei es Kopfhörer oder Freisprecheinrichtung im Fahrzeug.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@paul21457 let us know how your Wifi is. BT and WiFi are internally connected. This could be an antenna issue. You will have to open it up and check the coax connectors as well as the cables. If unsure, you can always post some pictures of what you see, with your Question. That way we can see what you see and hopefully can guide you some more. https://de.ifixit.com/Anleitung/Bilder+z...
Since iFixit does not yet have a specific guide for that, use something like this video to work on your phone.Check around the 3:40min mark and you see the connectors on the Sub board. Now, if your connectors are good and the wires are good then it is possible that this is related to the sub board. It is not to expensive and I would consider changing it, depending on what you find out when you work on it.
Of course, all of this implies that you already have checked your software settings, that you have made sure all of your software is updated and that you reset your network settings etc.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
@paul21457 lass uns wissen, wie dein Wifi funktioniert. BT und WiFi sind intern miteinander verbunden. Das könnte ein Antennenproblem sein. Du musst das Gerät öffnen und die Koaxialstecker sowie die Kabel überprüfen. Wenn du dir unsicher bist, kannst du immer ein paar Bilder von dem, was du siehst, mit deiner Frage posten. Auf diese Weise können wir sehen, was du siehst und dir hoffentlich weiterhelfen. https://de.ifixit.com/Anleitung/Bilder+z...
Da iFixit noch keine spezielle Anleitung dafür hat, verwende so etwas wie dieses Video, um an deinem Telefon zu arbeiten.Schau dir etwa bei Minute 3:40 die Anschlüsse auf dem Subboard an. Wenn deine Stecker und Drähte in Ordnung sind, ist es möglich, dass das Problem mit der Subplatine zusammenhängt. Je nachdem, was du bei deiner Arbeit herausfindest, würde ich in Erwägung ziehen, sie auszutauschen.
Das alles setzt natürlich voraus, dass du deine Softwareeinstellungen überprüft hast, dass du sichergestellt hast, dass deine gesamte Software auf dem neuesten Stand ist und dass du deine Netzwerkeinstellungen zurückgesetzt hast usw.
Während du an deinem Telefon arbeitest, solltest du viele Fotos machen. Wenn du damit fertig bist, nimm diese Bilder und erstelle eine Anleitung für iFixit. Das wird der nächsten Person helfen, die ein Gerät mit den gleichen Problemen hat wie du. Es ist einfach und macht Spaß, diese Anleitungen zu erstellen. https://de.ifixit.com/Guide/new Die iFixit Community wird das zu schätzen wissen.
Reparieren ist Krieg gegen die Entropie!
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Paul wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 35
