Zum Hauptinhalt wechseln
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
Battery Issue - Shutting Off When Bumped
When playing with my PSP 3000 if I bump it or put it down on a hard surface or shake it, the device will turn off. The battery is brand new. I also used a backup battery that is also new and the same think will happen. It was suggested to clean the contacts (isopropyl alcohol to the rescue) and build a foot at the bottom of the battery to make sure the contacts stay in contact with each other. What materials would be good for building the foot out of and are there any other solutions to this issue? Thank you.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi!
Well, it could be battery related, but what also happens sometimes with the PSP is that some IC falls of from the motherboard… it’s possible that some IC is “loose” and starting to come off. So I recommend to open it up and check if the motherboard is still OK.
Sorry for the bad news, but this thing would be more likely…
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
David wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 79
