Zum Hauptinhalt wechseln
Ein Spitzengerät aus der Familie von Kaffeevollautomaten der Marke Melitta. Typ F74/1-100
Not delivering coffee and leaking clean water
My machine is grinding the beans, then goes through the motions to make coffee but at the point it would deliver coffee nothing happens you can hear a soun from the exit hole but nothing come out, then it froths and delivers the milk.the grounds are wet and hot but then water leaks from under the tray. The water is clean doesn’t look like it’s been through the beans. I’ve cleaned the brewing unit run descaling
edit
I managed to get it working but it’s started again. It grinds, sounds like it producing coffee, but no coffee is produced, water is in the tray and underneath the unit with very wet grounds in the bin. I’ve tried changing the grounds finer and courser. I’ve tried using ready ground coffee it’s doing the same. I’m googled eyed with googling for answers.
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
@rose10230 let's see if our coffee maker Guru @vauweh has a solution for this.
von
he Is very helpful.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@rose10230 There are some possibilities:
  • a weak pump
  • a worn out drainage valve
  • the ceramic valve does not work
  • a faulty drive or motor
As far as I know the Melitta has no testmode, and its a little difficult to find the reason. Hmmm.
So: First I would open the device and have a look. Can you hear a strong sound from the pump? You even may open a connection of the hoses and watch, Ift the water flows strong. The drainage valve and the drive is the same as in other Melittas, use the corresponding guides. The ceramic valve manages the water flow. I fear the ceramic valve ist the culprit, find it and replace it. We have no guide for Melitta, perhaps you take some fotos and write a guide for us all? But we have guides for Jura, which is nearly the same, it may help.
Hope you can do it yourself, or you find a helping hand. Tell us, what happened.
Melitta Caffeo Barista T Öffnen Bild
Anleitung
Melitta Caffeo Barista T öffnen
Schwierigkeitsgrad:
Mittel
Jura Jura Keramikventil reparieren Bild
Anleitung
Schwierigkeitsgrad:
Mittel
War diese Antwort hilfreich?
Bewertung 1
If you pull the brew unit apart - there is a crema ball that the coffee is forced by to give the top of the coffee a creamy texture. It's like a piston that rises and provides friction to the coffee.
There is an o ring - twice now, the o ring has failed and the coffee bypasses the crema ball assembly and goes by the o ring. I have a photo of the blown o ring. I simply replaced it with the nearest o ring I could get from my local plumbing store - no chance of a metric o ring on a Sunday afternoon in the US. The original brew unit I replaced so now it's fixed I have a backup ready to go - I am at around 15000 cups so it's time.
Bewertung 0
1 Kommentar:
In mine all small seals look like brand new (16000 coffees). I replaced only the main brew cylinder one as was chipped, however all the water flows through the top safety valve. It remains closed all the time (metal strainer side) and all water goes straight through the top hole. I could not fine this part itself and ended up spending £66 on replacement brew unit (plus £29 for all seals and pipes service set)… I hope the new brew unit will sort this problem
von
Antwort hinzufügen
Rose wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 81
Insgesamt: 1,300
