Zum Hauptinhalt wechseln
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
How to repair GPU
GPU killed itself about 2 years ago and I've found no one willing to repair/replace it or tutorials online. If it really is impossible to fix, how should I go forward? This thing has too much precious data to lose
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
@turkeylegs lets see if our game console Guru @dan0 has any ideas on this one.
von
Sorry for the late response again, my friend.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@turkeylegs on your 360 S the GPU is part of the CPU. It is not impossible but will require to have the tools to do a total reball. That means you would at minimum need the stencils, a BGA reflow machine and a new processor. That is where you run into trouble. Those do no longer exist. That means you would need to use an old/used processor. Nobody can/will work with processors that nobody knows anything about. Think about it, you may be buying somebody else's problematic chip.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I totally agree! So, the best thing to do is to buy a known working motherboard in this case. It IS more expensive… but will save you a lot of time as it is way easier!
von
Antwort hinzufügen
Turkeylegs wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 180
