Zum Hauptinhalt wechseln
Das Acer Aspire V5-122P-0468 ist ein Laptop mit 11,6-Zoll-Bildschirm, der ursprünglich ab 2013 hergestellt wurde.
No doubles when typing
For whatever reason I can’t type double letters. Pressing any key twice the computer won’t recognize the second press For instance to type button I have to do but (pause ) ton otherwise if I do it normally it only types buton . Any idea what happened?
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
@kellibergi21474 I assume that it eventually lets you type the second letter just with a delay, correct?
von Teilen
You are correct
von Teilen
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@kellibergi21474 sounds like a keyboard issue. Try and use a USB keyboard and see if the keys now recover quicker. It does sound like your keyboard may actually be worn out.
If a USB keyboard does work the way it should then you might consider replacing your computers keyboard. The keyboard is intended to be part of the top case. That means it is not the easiest to replace. There are no guides for this specific task yet. Use something like this video to get to the keyboard. Around the 6:35 min mark you see that the keyboard is attached to the top case, usually via some plastic tabs that need to be broken off. Then you can get a replacement keyboard and attach that with some small screws. Of course, you can also try and find the top case with the keyboard already attached, but that is usually a bit more costly while the actual work is still the same (minus replacing the keyboard).
If a USB keyboard does not work then the issue could be Windows settings. Consider adjusting the keyboard repeat delay and rate in the Control Panel, or running the keyboard troubleshooter. Might be different for your version Windows since we do not know which version yours is
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thank you for your answer however when I hooked up a Bluetooth keyboard to my computer it did the same thing. It wouldn’t let me type doubles
von Teilen
@kellibergi21474
Did you try adjusting the Control panel > Keyboard > Speed > Character repeat settings, you never said?
von Teilen
@kellibergi21474 that is kind of good -) in that case you know that it is very likely not your hardware but a settings issue.
von Teilen
Antwort hinzufügen
kelli0427 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 232
